It is currently Sat Jul 26, 2025 8:41 am
PostPosted: Sun Jun 05, 2005 2:04 am
With the talk about Buying reverse Kerf in Bulk I got to thinking. What are the pros and Cons of reverse Kerf verses regular? I've never used Reverse kerfed lining.arvey38508.4617361111
PostPosted: Sun Jun 05, 2005 2:45 am
I think if it is installed cleanly it certainly looks better than the triangular variety, but it can be a bit of a challenge to get it in there without breaking it, and the breaks really show.
And... I suppose it is probably stiffer (some), but I have not tested this theory.
PostPosted: Sun Jun 05, 2005 3:33 am
Arvey I think the sides are much stiffer with the reverse kerf linings. It forms what is similar to a laminated beam when glued to the sides. I always spritz mine with a bit of water and bend on a hot pipe. It just takes a light touch because that thin outer face of cedar bends rather easily and you only need to bend the tight curves. A close approximation is good enough to keep them from breaking.
PostPosted: Sun Jun 05, 2005 6:26 am
Pros: they look much better, they ad a lot of stiffness to the side
assembly.
Cons: they break easily and those breaks are difficult to hide,
you have to be pretty careful not to make a mess with the glue
as it will fill the kerfs and look terrible.
PostPosted: Sun Jun 05, 2005 8:06 am
Ive use both, I like the reversed better, as mentioned, it makes the sides MUCH stiffer, You can remove your rims from your mold after the kerfing is installed, cant do that with the regular stuff. Ive yet to brake a set installing them, Kathy Wingert gave me a tip several years ago, and its worked flawlessly, Soak them in warm water for a few minutes before installing them, lay them out on paper towel to soak the excess water first, then glue as normal. Works every time for me.
PostPosted: Sun Jun 05, 2005 1:19 pm
Cool tip, Lance! Thanks. So, no need to pre-bend? What glue are you using?
PostPosted: Sun Jun 05, 2005 9:47 pm
JJ, I use LMI white.
PostPosted: Sun Jun 05, 2005 10:08 pm
I like good old triangular linings better.
they look more traditional,are easier to work with, and are lighter. I stiffen my sides with veneer strips anyway.
i just like `em better.
Matt
PostPosted: Mon Jun 06, 2005 12:33 am
[QUOTE=LanceK] JJ, I use LMI white.[/QUOTE]
Maybe I just move too slow, but I find the LMI white glue tacks up too fast.
... but now that I think about it... maybe since your linings are a little wet before you apply the glue helps with this.
hmmm....
Do you put glue on the entire strip before putting them in?
Brock Poling38509.3994560185
PostPosted: Mon Jun 06, 2005 12:59 am
yup- I lay it out, run 3 long beads of glue down the entire strip, then use my finger to spread it out, then start at the neck block, getting a nice tight fit, and clamp my way around, when I get to the heel block, I mark were it needs to be trimmed and then hold a wood block behind it, and using a razor saw, trim to length. The whole process takes me less than a few minutes.
PostPosted: Mon Jun 06, 2005 1:37 am
[QUOTE=LanceK] yup- I lay it out, run 3 long beads of glue down the entire strip, then use my finger to spread it out, then start at the neck block, getting a nice tight fit, and clamp my way around, when I get to the heel block, I mark were it needs to be trimmed and then hold a wood block behind it, and using a razor saw, trim to length. The whole process takes me less than a few minutes. [/QUOTE]
Would that be your high tech glue spreading device Lance?
PostPosted: Mon Jun 06, 2005 1:50 am
Nope- that would by my thumb
PostPosted: Mon Jun 06, 2005 1:51 am
Yeah, those glue spreading sticks are the best.
I clearly just move too slow. I take lots of time getting them lined up to stand just a shade proud of the sides, fuss with the clamps to make sure everything is down tight, etc.
Good thing I don't do this for a living..... I would definitely starve.
PostPosted: Mon Jun 06, 2005 2:02 am
well, now if you include all the little things like cleaning up the squeezout, and adjusting the clamps here and there, ya, it takes a bit longer, but just to get them on and clamped down, a few minutes usualy does it for me. Plus, Brock, I think you hit the nail on the head, about extending the open time of the glue with the added water from soaking the linings.
PostPosted: Mon Jun 06, 2005 3:19 am
I use hide glue which might make it a bit tougher
PostPosted: Mon Jun 06, 2005 4:01 am
I also use hide glue and getting everything together within 60 seconds is a challenge. For my process, I'd like to have the strip measured and formed before applying the glue.
I'm going to try the bending process on the Fox bender with pre-soaked liners first to see if I can do it without cracking.
PostPosted: Mon Jun 06, 2005 8:52 am
someone have one reverse kerf they could send me? I just need one full
piece! I have a guitar I need to replace one side of linings but I'm all out..
I've switched back to the std. Triangular again... for now... if you can help
me out shoot me an e-mail. I'll pay shipping costs and the cost of the
lining but I just need one of mark ketts linings....
PostPosted: Mon Jun 06, 2005 9:19 am
If no one has filled your needs yet, I can help you out.
PostPosted: Mon Jun 06, 2005 9:23 am
Thanks brock that would be sweet.
I'll e-mail ya.
PostPosted: Mon Jun 06, 2005 9:40 am
Ok... I will keep an eye out for it...
PostPosted: Mon Jun 06, 2005 11:02 am
John I also have a bunch, and can help you out.
PostPosted: Mon Jun 06, 2005 1:37 pm
Thanks for the offer matt, but brock is hooking me up. I appreciate it.
PostPosted: Mon Jun 06, 2005 1:56 pm
John,
Why did you switch back to the standard?
Jeff
PostPosted: Mon Jun 06, 2005 3:38 pm
Here is the long and short.
The short: Beacause I'm fickle
The long: I like the look (I like the look of reverse too....) it has less mass,
and is easier to deal with patching two pieces together...
Users browsing this forum: Bing [Bot] and 13 guests
